oil leak
05-02-2013, 12:57 PM
oil leak
I'm getting a little oil leak on the lifter blocks. Everything tight an new gaskets. Any suggestions on what to do???
05-02-2013, 01:00 PM
Its the front lifter block on the side against the motor.
05-02-2013, 04:40 PM
Lifter blocks can crack, its usually a shovelhead trick but don't see why not on an evo...are you sure it isn't the pushrod tower seal?
05-02-2013, 08:45 PM
Yea I've cleaned it an let it run an watched it. I don't c any cracks. I checked unless its on the buttom.
05-02-2013, 08:54 PM
my front lifter block is always wet with oil too, but mine's coming from the breather.
where's your breather routed to? I know i'm seeing quite a bit more blowby since i bumped the compression/cam (hopefully fixing that when I install the roller rockers next week)
05-03-2013, 07:01 PM
Well checked tonight an its cracked!!!! They are s&s blocks an s&s cases. Wonder if a hd would work withthose cases? Buddie has a hd one!!!
05-03-2013, 07:11 PM
Quote:
Originally Posted by
01 chopper
If the H-D gasket lines up with the S&S block then there is a good chance it will work.
05-03-2013, 07:47 PM
Good news i got ahold of s&s an they told me it would work!!! Hell ya be back riding tomorrow!!!
05-04-2013, 08:07 PM
Bike is back to running today!!!! Thanks to bill at Ruff Road Cycles!!
harleyjames123
09-10-2024 12:05 PM
prplglide
EVO
09-22-2014 03:46 PM
RidemyEVO
EVO
05-06-2010 01:02 PM
rocky6068
Exhaust System Topics
01-25-2009 09:55 AM
JimboFXD
Ironhead
10-31-2007 06:31 PM
