Miss is back.
To check further ., spray water on the coil and plug cables and look for leaking arcs as you turn the motor over .
Replace anything that arcs when wet.
If the spark is ok., the carb. is probably the culprit.
corrosion on electrical connectors.
Your pic. showed enough corrosion to actually prevent a high tension spark at your coil and a part actually gave way when you diconnected the plug cable.
This is an indication that your 25 year old sled needs some TLC at ALL the wiring connectors and not just the ones that caused your immediate problem.
Suggest you go through your electrical connectors to clean and lube them as preventitive maintenance.
Look for the same greenish color corrosion and clean with a paste of baking soda and water , flush with water , let dry then lube and seal the connectors with dialectric grease. Repair any obvious weak wiring etc. by cutting back the wire and installing with new .
This should keep your 25 year old wiring system in good shape.
