well I got it to start! its the carb
04-08-2013, 10:43 AM
I finally got it to start I poured sum gas into the carb an she started first hit of button. But there's something screwed up in the carb. Not allowing it to get fuel. So I guess ill tear it down now an see???
04-08-2013, 10:45 AM
Oh the bowl had plenty of fuel in it. Just isn't sucking it up through.
04-08-2013, 10:47 AM
Remove the gas tap and check it is clean, check there is no obstruction in the pipe from tank to carb - work methodically from where the gas is right through. In the carb the float valve may be stuck, or float level too low.....
04-08-2013, 11:35 AM
I had a clogged jet on mine once. The ethanol in the gas eats up the fuel lines inside an gunk can float to the carb an get sucked in the jets.
04-08-2013, 03:41 PM
I took it apart an looked like the slow jet was clogged up. I blew through everything to make sure. I'm gonna put it back together tonight to try it.
04-08-2013, 04:56 PM
04-08-2013, 05:06 PM
Quote:
Originally Posted by
01 chopper
That's the hard part.
Maughanaj
09-23-2017 01:30 PM
smittyhasahog
06-12-2014 06:17 PM
lagrato53
Carburetor Related
03-13-2014 06:31 AM
randybecker
09-14-2011 11:29 PM
Good ol boy
07-23-2011 09:02 PM
