1988 FXRS-SP - Air Assist Anti-Dive Part Number
Howdy folks...
Trying to find a part number and wondering if anyone out there might be able to help me out.
I recently swapped out the air assist anti-dive system manifold (this is the piece that the headlamp visor bolts into. The old manifold had cracked where it bolts into the front forks. Now I have an air leak in that system and my front forks are way softer than I'd like. I tracked the leak down to one of the 2 tubes that bolt into the top of the fork cylinder and connect at the back of the manifold. Trying to find the part number for this.The manual lists it simply as "tubes".
The part looks like a 2.5 inch length of aluminum tube, tapered at one end where it goes into the manifold, with a nut on the other end where it bolts to the fork.
Hopefully this makes sense.
Any help would be appreciated!
Thanks! I think I may have found it. Still only lists it as "tube" and I can't seem to find any images of it when googling the part number, but I think this is a good starting point for tracking the part down.
briandentler
08-03-2009 04:41 PM
