518 on the intake gasket / flanges?
Just as the title says. Should I use loctite 518 on my intake gaskets / flanges. I just dont want it to leak. On cars I usually use some type of rtv silicone but im new to bikes. Im having a hard time dialing the s&s super e in, since I cant turn the enricher off without it dying I suspect an intake leak. Should I use this tube of 518?
Might want to put a little loctite on the flange nuts but the gaskets just get a light coat of vaseline so they fully seat. Replace the voes vac line while you are at it. Did you test the manifold for leaks or doesn't it run good enough for that?
Ds
Ds
No voes ... it will run good enough to test for leaks but if I turn the enricher all the way off it dies. just got back from picking up carb cleaner, starting fluid, and some WD40. I have done a few searches and if I dont detect a leak am I correct in assuming my idle slow speed something or other needs cleaned?
Received 4,361 Likes
