Choke adjustment
You may have too much slack in the cable.
If I recall correctly the choke is adjustable as to where it grips the cable. Disconnect the cable, play with the choke and you will see how far it needs to move to raise the idle.
Set it so that it is not "on" when the choke is pushed in....easier to do than describe and its a coupla years since I messed with a butterfly but I am pretty sure that's how it works.
Collk88
Exhaust System Topics
11-15-2012 07:50 AM
WadsChopShop
06-17-2010 08:49 PM
