ring end gap range
ring end gap range
hey folks,
so was gapping my rings as per wiseco instructions... needed to bring them to .015, top and bottom rings
first time grinding with appropriate tool and opened one of the rings a bit too much at .018
...am i safe, or should i just get another set and do it again?
thanks, paul
thanks, paul
Received 4,632 Likes
I'd say put the wide ring on the bottom, might just keep a less carbon from getting to it, let the smaller gap ring deal with the direct compression. I'd side with the back cylinder comment, too; no need to give it extra cooling, won't be binding for sure. While perfect is good, it's better to be on the loose side than too tight. Here's a nice tutorial for putting it all back together, and gaping the rings, might have some tips you haven't heard of:
http://www.nrhsperformance.com/tech_...assembly.shtml
well, i ordered another set anyway...they were inexpensive enough
and yes, that nrhs info is great!.... i bookmarked it long ago and followed their directions when i did my first build...the only thing i didn't do was muck up the piston and walls with that redline engine lube...but think i'll do it this time
