Unedited: Adding a second relay to fix the dreaded click
#52
Received 4,361 Likes
I just unplugged the 87 connector of the original relay and ran a wire with a 20 amp fuse from the battery to the 87 connector on the relay and the bike starts fine.
I did not add a relay.
I wrapped the original 87 connector with some electrical tape.
Now to see if it stands the test of time.
edit: every where I put 87 I should have put 30 oops.
#53
#54
If you truly did this and got the numbers right, there is some seriously messed up wiring on your bike! The 87 tab of the original relay is the output to the solenoid, nothing else. Disconnecting it from the relay effectively removes any chance of the solenoid getting any juice at all. Connecting a 20amp fused wire from battery positive to the 87 tab doesn't do anything, either, because the tab is dead unless you push the start button, and then it is 12v positive already.
I guess I got confused in the 100 degree heat in my garage.
#55
#56
The relay seems to be working correctly.
#57
Looking at my wiring diagram, tab 30 is connected to and gets it's voltage from the ignition switch. You disconnected that feed and fed it direct battery power. Tab 87a is connected to the direct battery power any time you are not pushing the start button now. Tab 87a goes through the accy breaker where it branches off to the horn and the dash lights, etc.
So does your horn and or dash lights work all the time now?
#58
I see why it seems to work. The start button gets it's juice from the kill switch, which gets it's juice from the ignition switch, which gets it's juice from the main circuit breaker. When you turn off your ignition switch, you kill the feed to the kill switch and starter button. You do NOT kill the constant feed to the acc breaker, which feeds the dash lights, brake lights and horn.
#59
#60
No, it does not. I`m not talking about the wire for the control voltage that actuates the relay, I`m talking about the supply wire that supplies the higher current that is sent to the solenoid coil.
