Unedited: Adding a second relay to fix the dreaded click
Old 11-24-2012, 01:12 AM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
Originally Posted by DirtyDave
Why not just add a push button on the starter? It's easy, cheap and works all the time.
I was ready to give you a ditto, but engineers and QC test these things for a whole lot of cycles. Thats a bandaid, it works but, side steps the initial issue, doesn't cure the problem. It's tedious, but, clean and lubricate all electrical connections and be done with it! jmho I didn't read all the posts, probably waay off base on this.
  #192
Old 12-01-2012, 07:05 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Cleaning the pin/socket connections will only get half of all contact points.
To really make sure you have a good connection at all points you have to replace all connectors.
The reason for this is that Harley uses a connector that just stabs a couple of tabs into the wire (no solder involved). Corrosion can build up in there and there is no way to clean it. The only way to make sure you have no corrosion is to replace the connector or bypass it.
As for using the push button on the starter yes it works but to me it is annoying to have to lean over and push it.
  #193
Old 12-02-2012, 12:00 PM
Fernf5's Avatar
Fernf5
Fernf5 is offline
EDIT: Deleted till I can check my wiring further.
Attached Thumbnails Unedited: Adding a second relay to fix the dreaded click-flst-wiring-hd-forum-003.jpg
  #194
Old 12-02-2012, 12:26 PM
Nightshift22's Avatar
Nightshift22
Nightshift22 is offline
6th Gear
after reading this post ,i went to work and install a second relay
very happy with it ,at least it work for now
went i bought my bike a month ago i had to lean over to push that starter bottom
now no more
Thank!
  #195
Old 01-23-2013, 05:26 PM
texashillcountry
Dirt don't hurt
Bump for a good thread
  #196
Old 02-04-2013, 12:54 PM
92Fatty's Avatar
92Fatty
92Fatty is offline
Bump can we make this a sticky??
  #197
Old 02-04-2013, 04:59 PM
traildog's Avatar
traildog
traildog is offline
Ask and ye shall receive......Thanks Terry!
  #198
Old 02-04-2013, 06:15 PM
texashillcountry
Dirt don't hurt
Damn, just ask a Moderator huh?
Too bad none of the rest of us were smart enough to do that..
  #199
Old 02-04-2013, 06:40 PM
traildog's Avatar
traildog
traildog is offline
Terry"TheTrollKiller" is the man......but......he declined to sticky the "Traildog on Bertha in a speedo" thread...........
  #200
Old 02-04-2013, 06:45 PM
texashillcountry
Dirt don't hurt
Terry must be a man of taste and discrimination.
Please tell me that you're not showing up to the NTL. Meet like that.
Quick Reply: Unedited: Adding a second relay to fix the dreaded click
