Unedited: Adding a second relay to fix the dreaded click
Old 08-27-2012, 02:57 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Originally Posted by HarleyReece
Update:
Took plunger out and hit it with some brake cleaner and re greased. Hadn't clicked at all today. We'll see how she responds in the morning.
Still may mod the wiring. I would only need to add wire from battery to 30 post correct?
Depends on what bike you have.
  #152
Old 08-28-2012, 06:59 AM
HarleyReece's Avatar
HarleyReece
HarleyReece is offline
Damn thing only clicks this morn.
Bike is a 95 fxstc, softail custom.
  #153
Old 08-28-2012, 02:02 PM
HarleyReece
This is in reference to my earlier post asking if my year/model is compatable with adding a fused wire from battery to pin 30 of relay. Thanks.
  #154
Old 08-28-2012, 02:06 PM
D1gger's Avatar
D1gger
D1gger is offline
Again, yes. All you should have to do is add the fused wire from battery positive to the "30" tab on the factory relay. If it's the original relay, consider replacing it with a new one as well. Good luck.
  #155
Old 08-29-2012, 09:19 AM
HarleyReece
What size fuse should be placed inline with the battery/ pin 30 wire?
  #156
Old 08-29-2012, 11:46 AM
texashillcountry
Dirt don't hurt
20 Amp.
  #157
Old 09-08-2012, 09:40 PM
texashillcountry
Dirt don't hurt
I spoke to someone yesterday that could have used this thread. So I figured I would give it a bump.
  #158
Old 10-06-2012, 03:47 PM
D1gger's Avatar
D1gger
D1gger is offline
Bumped for Bertha's sake...
  #159
Old 10-06-2012, 04:09 PM
traildog's Avatar
traildog
traildog is offline
Just read this again. Thanks, I'm going to look into doing this.
  #160
Old 10-06-2012, 04:10 PM
traildog's Avatar
traildog
traildog is offline
Bertha says thanks!
Quick Reply: Unedited: Adding a second relay to fix the dreaded click
