Unedited: Adding a second relay to fix the dreaded click
Old 08-23-2012, 03:04 PM
deuce40s's Avatar
deuce40s
deuce40s is offline
Probably a dumb question, but where is the plunger or how do I go about getting to it to clean it? Do I need to get inside the primary?
  #142
Old 08-23-2012, 04:07 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
To get to the plunger you have to take off the back of the solenoid. 3 bolts and your in. No messing with the primary.
  #143
Old 08-23-2012, 04:09 PM
D1gger's Avatar
D1gger
D1gger is offline
No pics as I am at work, but you don't need to touch the primary at all, at least on my bike. On mine, there's a chrome cover on the right side of the starter held on by two nuts. Once that is off, there is a small cover held on by three screws. Pull those screws and pop that cover off and the plunger will slide right out the right side. Make sure the battery is disconnected first to avoid getting juiced or engaging the starter by accident. It's pretty easy to get to and doesn't require removing the exhaust or anything else.
  #144
Old 08-23-2012, 04:15 PM
Nostalgia_93's Avatar
Nostalgia_93
Nostalgia_93 is offline
Thank D1gger, Texas!
I imagine all is done inside, by first taking off the starter's solenoid push button cover (or regular starter cover if you have that) Am I right?
Cheers,
  #145
Old 08-23-2012, 04:30 PM
HarleyReece's Avatar
HarleyReece
HarleyReece is offline
What kinda grease? Any kind due? Got some ball joint grease in the gun, could I use that?
  #146
Old 08-23-2012, 04:37 PM
D1gger's Avatar
D1gger
D1gger is offline
Cheers,
The pushbutton cover if you have one actually replaces the cover Texas and I are referring to. I used wheel bearing grease, but the key is something slick and a very light, thin coat. Too much and it will attract carbon and gum up over time, becoming sticky.
  #147
Old 08-23-2012, 05:54 PM
Nostalgia_93
Ok, thanks! Yes, I've got the button. Just wanted to be sure :-)
Cheers,
  #148
Old 08-26-2012, 10:57 AM
bstacey's Avatar
bstacey
bstacey is offline
ran the wire from positive battery to # 30 on the relay. worked like a charm on my 95 flstn. thanks
  #149
Old 08-27-2012, 11:25 AM
HarleyReece
Update:
Took plunger out and hit it with some brake cleaner and re greased. Hadn't clicked at all today. We'll see how she responds in the morning.
Still may mod the wiring. I would only need to add wire from battery to 30 post correct?
  #150
Old 08-27-2012, 02:19 PM
D1gger's Avatar
D1gger
D1gger is offline
Originally Posted by HarleyReece
Update:
On a softtail, yeah, just add the wire to the 30 post.
Quick Reply: Unedited: Adding a second relay to fix the dreaded click
