Unedited: Adding a second relay to fix the dreaded click
Old 08-02-2012, 08:42 PM
schwangster's Avatar
schwangster
schwangster is offline
Sounds like mine.
If I leave her overnight, 19/20 times I have to hit the button on the solenoid and make her turn over a couple times. After that the starter switch works fine.
I have not determined the exact length of time I have to leave her 'resting' before she won't fire up with the start button. But overnight seems to be the key...
oh, and BTW.... SWEET ride !!!
  #112
Old 08-02-2012, 09:50 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
mdunn and schwangster
What is your battery voltage first thing in the morning?
It sounds like you aren't getting enough power through your handlebar switch to trip the relay.
  #113
Old 08-02-2012, 10:02 PM
schwangster
Not sure, but I did splice in extra wire when I added the 16" apes.
I also installed a hi-output headlight about the time it started to this. (2 years ago)
Should check it next time I fire up.
  #114
Old 08-02-2012, 10:10 PM
texashillcountry
Dirt don't hurt
Just to make sure I have it correct your problems started after you spliced an extra wire in and added a hi-output headlight?
I think your problem is in one of those two things.
Usually when something on my bike quits it is because of something I fixed.
  #115
Old 08-02-2012, 10:16 PM
schwangster
Same
not just on my bike, unfortunately.
I redid the splice last year(orange power wire, if I remember correctly)
As I mentioned, once I turn it over she will aways start up from the switch.
Almost as if she has to shake the cobwebs out.
The starter button on the solenoid has kept me in the game.
This winter I will do the relay fix and see what happens.
  #116
Old 08-02-2012, 10:17 PM
D1gger's Avatar
D1gger
D1gger is offline
I would almost have to say dirty start button contacts or weak battery, possibly poor connection on one of the battery connections, either at the battery or at the other end of the battery cables. Check/clean all connections and the start button and also as suggested above, check the battery voltage after it has sat overnight before you go to start it.
  #117
Old 08-02-2012, 10:44 PM
mdunn's Avatar
mdunn
mdunn is offline
Sounds like mine.
This is the exact same problem as mine....
Mike
  #118
Old 08-02-2012, 10:45 PM
mdunn's Avatar
mdunn
mdunn is offline
My voltage on my battery is 12.7 volts, thats plenty one would think.
mike
  #119
Old 08-02-2012, 10:48 PM
schwangster
thanks, D1gger. I'll check all the connections.
Battery was new last year, and still did it.
  #120
Old 08-03-2012, 08:34 AM
texashillcountry
Dirt don't hurt
mike
If your battery voltage is that good then I would say you have a connector problem. Once you start the bike it shakes and jiggles all the connectors.
Harley uses connectors that depend on two spikes to penetrate the wire jacket to make connection. It is my theory that after time corrosion builds up between the spikes and the wire and that is where all our problems come from.
Quick Reply: Unedited: Adding a second relay to fix the dreaded click
