starting issues
starting issues
so there i was. new solenoid and battery installed on my barn find 1985 harley wide glide/fatboy hybrid. hit the start button and CLICK. nothing. assuming this is the dreaded relay issue i called a few auto parts stores and tried to find a relay that matched the only one my bike has. nothing. which relay do i buy? is it a headlight relay? its made by Hella and the part number on it doesnt come back to anything other than a relay for a sunroof on some model car. any help would be awesome.
Your ignition controls the coil.
The center pin is used by the glides to turn off the head light while starting.
All you need to do is go and get a fused wire (about 8in long) put some ends on it (one ring end to connect to the battery and one female spade to connect to the relay) and a 20 amp fuse. You may need to add some wire to what you can get in the store.
Another guy had a similar problem and it turned out to be a bad connection between the male spade connection and the green wire (the starter end of the green wire).
What is your voltage at the starter (green wire) when you try to start your bike?
Just to be clear that is while you have the start button on the handle bar pushed correct?
