NAILED IT. relay was the issue. now comes part number 2. i shoot ether in the carb and she fires on 1 cylinder and wants to start but wont. i cleaned out the carb added fresh fuel. now i have noticed that this bike has an s&s carb on it. there is a lever right behind the air cleaner i can lift up about an 1/8 of an inch. what is that for? mine is not connected.
That lever is your choke and needs to be connected.
It should lift up much higher than 1/8 of an inch.
ok i fixed it and it lifts about a half inch now. it seems to be that she fires on ether but its not getting fuel. whats a carb rebuild kit run these days?
there is some spray that comes out the front of the carb. i have the air cleaner off. but choke or not it wont hit on fuel. im stumped. i know its a fuel issue but i cant see why if the jet is clean there is no fuel going into the engine. pulled the plugs and they are dry.
