starting issues
Old 02-09-2013 | 03:58 PM
Spanners39's Avatar
Spanners39
Originally Posted by greasemykey
40 amp and now this thing is acting hard to start and when i let off the start switch the solenoid wont turn off. its almost like its got a dead battery and wont turn over anymore.
Check the solenoid is connected properly, I had an Ironhead do this and it was the solenoid wired in wrong.
  #92
greasemykey's Avatar
greasemykey
Originally Posted by texashillcountry
Did you check your voltage on your battery? Yes I know it is new but you have been trying to start your bike for a while now.
actually no i have not.
  #93
Old 02-09-2013 | 04:04 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
it reminds me of a timing issue on older Chevy's. how do you adjust the timing on this bike. i see no distributer.
You adjust your timing with the ignition pick up in the cam chest.
On the right side of the motor you will see a round plate about 3' in diameter held on by 2 bolts. Take those 2 bolts out and you will see the ignition pick up.
Do you have a manual for that bike? If you don't I would advise getting one as they are very helpful.
  #94
Old 02-09-2013 | 04:06 PM
greasemykey
ok i got it to idle and rev but it keeps backfiring out the exhaust. even at idle.
  #95
Old 02-09-2013 | 04:07 PM
greasemykey
whats the timing supposed to be and how do you adjust it?
  #96
Old 02-09-2013 | 04:13 PM
greasemykey
ah yes old points and condenser. what is the factory gap on the points?
  #97
Old 02-09-2013 | 04:18 PM
texashillcountry
Dirt don't hurt
Between 15 - 18 thousandths.
  #98
Old 02-09-2013 | 04:27 PM
greasemykey
is that when its closed?
there is a hex head that rotates that opens and closes the points. right now its closed and there is 0 gap.
  #99
Spanners39's Avatar
Spanners39
Turning the backplate clockwise will advance the timing, retards the other way.
You can fiddle with it to see if it improves or you may still have a manifold leak.
  #100
Old 02-09-2013 | 04:29 PM
Spanners39's Avatar
Spanners39
Gap is when open, hex head is the advance unit, don't rotate the motor using it or you will snap off the bolt. Rotate motor on kickstart if fitted or with the rear wheel. I usually mark the back plate, remove the screws and rotate the plate until the points open, adjust and then put back at the mark i made.
Quick Reply: starting issues
