Jiffy or Center?
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
I have a display stand, which mounts at the front of the engine and holds the bike upright. It is much wider and more stable than a centre stand, also doesn't limit ground clearance. You can see it folded up under the boards below. The bike takes up less space when parked in the garage, also it helps with maintenance.
Well I use a center stand any time I'm on fairly level solid ground. Any other time Jiffy. Not a lot of folks have center stands so it's fun to get the reactions and comments I get. I have the EZ-Dock and you can put the bike up on it while seated. It does take just a little practice though. The first time I tried I wimped out. I can't say there's a trick to it exactly. More like trusting it's going to work.
grbrown and all,
Thanks for the input regarding my jiffy stand vs. center stand. I think I am going to be looking into purchasing either a display stand - or a center stand. There's times when I would rather have the bike (97 RK) on a center stand (when flat ground is present), and also for maintenance issues on the road etc. I think it would complement the factory jiffy stand.
Anyone every have any issues with the center stand scraping on corners etc? I don't lean my Road King over to far in corners, so I don't think it would be an issue. Probably just pot holes and bumps would be the only worry?
Anybody know if this center stand will fit my 97 Road King, with stock suspension: http://www.ebay.com/itm/Wheel-Dock-H...9c3de8&vxp=mtr
There is a recent thread over in Touring about centre stands dragging. Apparently it is the pivot or mounting that hits, not the feet. Might be worth calling in there to take a look. Frankly a display stand works so well and avoids any such problems that is what I recommend, given the choice. In addition, if you decide to fit a True-Track stabilizer kit you can with a display stand, but not with a centre stand!
There are several secondhand ones on Ebay and you may be able to buy one for around $50, by the look of it.
Thanks for that info! Seeing as I have a True-Track on my 97 RK, I will have to go with the display stand, as you mentioned. It just hit me last night - I figured that the center stand idea would be out, with the stabilizer kit on my bike. I will surf Ebay and see what's on there. Thanks again!
