Problems with Ev 27 install on 98 Evo
found the vibration cause probably
Even though I inspected the rear motor mount less than 4 weeks ago I decided to rule out any other cause for the vibration and low and behold there it was all cracked at almost every metal-rubber joining. I ordered one and should be good to go. I also bent the chrome guard for the stator plug so that it keeps constant pressure on the plug. I thought it was just a guard as it never touched the plug since I had the bike. I will have to adjust timing though. When she starts she most of the time starts on just one cylinder then the other gets going. When I get home I want to get her warmed up for a few miles and then do the adjustment.
Pinetop
Pinetop
finally finished this project
Another problem arose. The valve guides were smashed by the new cam. A racing mechanic finally found my problem when he looked at the valve guides. We took the heads off and shaved the top of the valve guide on the heads and lapped the valves for perfect seal. Just a w ord of caution for owners doing their own work, When they say bolt in cam is easy install it is not. There are a host of problems waiting to catch the inexperienced. ul I read as much as I could and even though the manual has a caution about valve clearance I read it as clearance between valves and other valves and/or pistons not the top end problem I encountered. So among the previous problems I mentioned this one very important.
Changed rear motor mount and it fixed the mid engine vibration but the mechanic I consulted found that somehow I had contorted the engine and top bracket which caused not only the rear mount to break but also the front. Must have resulted from drive belt install when instead of following the manual my brother did his trick and I paid the price for the shortcut.
Pinetop
Pintop
Pinetop
Pintop
yes we all know what you want to say but you cant blame the push rods because of human error. 90% of all adjustable pushrod failures are caused from the person that's turning the wrench.
Yes, exactly, which is why I don't recommend people use them ESPECIALLY with new lifters, yet people still talk about them as if they are an essential upgrade.
On a forum like this, where we have no way of assessing the competence of the end user, we should really not be promoting their use as you have to have your **** together to fit them.
I shall not mention them again....
