Explain SA&S Super
Explain SA&S Super
Hi,
While I've owner a number of bikes, this is my 1st Harley. A 1989 Electra Glide Classic, fantastic bike, most comfortable I have ever owned.
I see the side of the carburetor says "S&S Super" and I can see a module underneath the bat fairing that has "Screamin Eagle" on it.
Can some tell me what these are exactly? My initial guess is aftermarket pipes have been added and the carburetor replaced to match??
peace,
Chuk
peace,
Chuk
As far as the S&S Super, I replaced mine from a stock CV carb. For me this has been a great change. I have a 1991 evo. pretty much stock. bored 10 over, Wisco flat top pistons, 9.5.1, S&S oil pump, Drago's 2/1 exhaust system, putting out 75 hp 85 ft lbs tq. Not sure if this helps you out. I put 2 parts kits P/N 35-0416 over time and then went to the S&S. All I have done to it is re-jet for pipe change. I like the sealed intake much better on the S&S then the CV rubber mount type.
1 Post
The S&S carb is a butterfly valve type carb, kinda like 1/4 of a Holley carb. They make good top end power, but tuning the mid range can be problematic. If they work for your bike, they are a great performance carb.
I had a Super G, but ended up going to a 48mm flatslide Mikuni. The slide mounted metering needle makes mid throttle adjustable.
Admittedly my carby is only a few years old and the E here may be much older, but my perception of S&S carbs is that they were commonly installed, especially on shovels way back, by ignoramuses who didn't know owt about carbs, but had to have that air filter!
Chuk makes no mention of having any problems with his - why it may even be running like a top!
That's just a tad unkind, old chap! My S&S V107T came with a Super G. It is a touring motor, gives a smoooooth flat torque curve and similar fuel consumption as my c/v did on my 80".
