I'm about to do my winter project, which is putting an EV27 cam into my 99 Springer, but I have an interesting question about the size of the cam bearings.
Is the Evo cam bearing the same size as the twin-cam bearings?
I've a couple of brand new, still sealed S&S bearings for a TC & wondering if I can use one of them in my 99 Evo motor.
That 99 probably has an INA inner cam bearing Replace it with the old Torrington inner cam bearing P/N (on Torrington bearing outer cage ) B 138 Special bearing extractor and installing tool required I use a Trock tool (out of business ) others available
I recently replaced my cam bearing in 1991 FLT and used Harbor Freight blind bushing puller and bushing driver kit. No problem. Before installation, I froze bearing and heated area of case with hair dryer. Went in easy.
