Clutch Cable Question
I know when I replaced my cable the firs one was too short. When I went back to the dealer to verify had the correct one an old grizzly parts guy remembered that the 95 and 96 models had a couple different options and found me the proper one.
Received 4,361 Likes
When I had my '89 Ultra, I found the center clutch cable stretched after some use. The adjustment was near the end of threads and I was not comfortable with the adjuster on the end of the threads. The cable appeared to be just too long for the housing. It was the correct part number. The only way that Harley said to fix it was to replace the cable with a new one. I bought a new cable assembly. But after less than a year, it did the same thing.
I didn't want to spend more money so I cut the cable (the first one) and inspected the cable inside the housing. It appeared good without any broken strands. So I took off the end of the cable housing that mounted on the transmission adjustment. I used a hack saw and cut a slot in it. I slipped it on the end of the new cable. It made the cable housing just the correct length and lasted many years.
It might be hard to make the plates fully release by hand with cold oil, same reason that first shift into first gear gives more clunk and you feel the bike try to move,
and with the engine apart, no compression to hold engine from turning when you try to turn the wheel and release the clutch, I think your OK.
Okay, I'm going to wait until I have the motor back together and running and see if that's the problem. Thanks.
