How to change a drive belt 101 Pt 4
Old 12-10-2012, 05:08 PM
bluharley's Avatar
bluharley
bluharley is offline
I'm still trying to figure why I had to drop the swingarm....I guess I could go look at the bike, but I'll stew about it for a while. The book right here tells me I had to.
Old 12-10-2012, 06:18 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Yours is a tourer isn't it? Frames are different. Mind you, they say to drop the swing arm on FXR models but I dont.
Old 12-10-2012, 08:31 PM
LowriderHarold's Avatar
LowriderHarold
LowriderHarold is offline
Default Cool
Thanks for taking the time. Will be a project prolly in the spring. One question for ya. Also plan on doing a top end re-build as well & bumping compression up to 9.5:1 & while having the clutch out , upgrading starter ring gear & pinion gears to 10/84 teeth in order to gain more torque. Are these parts worth the coin. Seems like cheap insurance of turning over a higher compression motor. Cheaper than a high torque starter.
Ride safe,
Harold
Old 12-10-2012, 08:36 PM
Spanners39's Avatar
Spanners39
Ride safe,
Harold
I wouldn't bother at 9.5:1 myself, just put some fat-*** battery and starter leads on it, I generally use welder lead, its really fat and has multiple cores....makes a big difference for not very many dollars.
Old 12-10-2012, 09:41 PM
Broncobilly72's Avatar
Broncobilly72
Broncobilly72 is offline
Spanners,
Thanks for taking the time posting the drive belt changeout tech! I need to do this on my 97 RK, before next riding season.
Old 12-10-2012, 10:55 PM
IronWright's Avatar
IronWright
IronWright is offline
Old 12-11-2012, 12:23 AM
Spanners39's Avatar
Spanners39
I used to use the carbon fibre falcon ones, (at the time I did this but there have been some delamination issues (not with any I have fitted) so I use stock now.
Old 12-11-2012, 05:06 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
The belt on touring bikes is trapped by the frame, which is why the swingarm has to come out. The executive summary is: support the trans (in addition to lifting the bike), remove rear wheel, then passenger footboard supports and rear rubber mounts, withdraw swingarm axle from trans, remove swingarm.
Old 12-11-2012, 08:17 PM
Kushman's Avatar
Kushman
Kushman is offline
Nice job Spanner . When will we see the series of instructional videos ?
Old 12-11-2012, 08:56 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,762 Likes on 2,016 Posts
Good tutorial, Spanner. On the Softail, the rear wheel and swingarm have to come off too.
Quick Reply: How to change a drive belt 101 Pt 4
