crank position sensor plug?
does anyone make a plug to cap off the crank position sensor? (I've eliminated the MM efi, and want to get rid of all the misc. wiring/sensors/etc that I can)
I found a plug that comes with S&S crate engines, but it appears to be a slightly different bolt pattern than the hole on the evo case
worst case, I can probably make something, but seeing as I dont have access to a machine shop, its going to mean a lot more work than it really should be (honestly the biggest reason I want to remove it is because it gets in the way of removing the oil filter, and I'd just as soon making a mess on my garage floor next time around)
04ctd
09-18-2008 07:44 PM
