New stator bolts?
If the stator came loose it can do a number including locking up motor. Not sure why you would need to reuse bolts but if I had to I would only do it in a real pinch and then use permanent red loctite. Of course if you ever needed to get them out you would put a little heat on them. Just my opinion.
Do not use red loc-tite, the heat takes the seal out and you could pull the threads out. Loc-tite does not normally reccomend red loc-tite on 1/4" bolts, especially when they go into aluminum. Go to their web site and look at the reccomended liquid for various applications. They are grade eight bolts that are not torqued down that tight so no stretch at all. The only reason HD wants them replaced is because of the loc-tite patch, You can put a drop of blue and you have the same thing.
John
John
Under no circumstances reuse anything ....replace entire bike immediately to eliminate all chance of failure ...lol. My 84 still has the factory bolts, been reused numerous times...and I would reuse them again tomorrow without a second thought.
( Sorry Op!)
