Primary Chain
10-24-2012, 12:31 PM
Dirt don't hurt
Primary Chain
I bought a Diamond Primary Chain to replace the worn out one I had.
My question is - Do primary chains require a break in period?
I can hear it in there and it sounds like it is loose but when I open the access port it is tight.
Has anyone else used them?
10-24-2012, 12:35 PM
The only new primary chains I have had are when the bike was new, so running it in, then when installing my S&S motor, so same ritual. We run tyres for a break-in period and it seems reasonable to do the same with a new chain, for a couple of hundred miles or so I guess.
10-24-2012, 06:18 PM
I don't know if I would call it a break-in period, but they do stretch a bit at first so keep an eye on the adjustment.
John
10-24-2012, 06:29 PM
I'd guess if the previous chain was really stretched, the new chain might be having a bit of a go getting used to the worn sprockets.
10-24-2012, 09:19 PM
Dirt don't hurt
Thanks for the replies.
I guess I will just call it a Harley noise and forget about it.
10-24-2012, 10:10 PM
FWIW, if I listen, I can always hear my primary chain. Just check it after the first 500 miles and make sure it's still in adjustment.
10-24-2012, 10:21 PM
I always replace sprockets when replacing chains. Must say havnt seen too many worn out primary chains.
sgw1064
01-08-2023 09:19 PM
Nathaniel King
EVO
15
06-11-2016 07:53 AM
Lobeau
08-21-2015 12:50 PM
daveinlaw
02-21-2011 09:53 AM
gabulldog
04-02-2009 05:42 AM
