Checking RPM
Checking RPM
I tried searching but couldn't come up with much. Im trying to find a way to check what my bike is idling at while at idle. Is there a way to check this besides getting a tach? My bike idles great when it's just started and warmed up enough to take off choke but after a little ride and stopped at a light or something it sounds like it is idling high.
Adjust the idle after it is fully warmed up (when it's idleing high).
If it idles on it's own in under five minutes when you cold start it, it will probably idle too high when the engine and carb fully heats up, depending on ambient air temps.
Make very small adjustments to find a happy medium between cold and hot idle speed.
Lil'Mugsy (01-28-2021)
1999 flstf (01-27-2021)
Find a friend or a shop that has a "dial back timing light" the better ones have a digital tach on the back of them. That is what we use to set the idle on bikes that have no tach. Set the idle at about 900RPM's wit the bike warmed up. I believe Harbor Freight has these for a reasonable price.
John
John
MrMe24 (01-25-2023)
