Fix for a stiff choke?
When I pull the choke on my TG, it feels rather stiff. I'll start the bike, and it'll run 1000 to 1200 rpm for maybe 10 seconds then drop to around 800 or so. The bike will start to stall, and I'll have to grab the choke and pull it out again. It's a repeat until necessary process. Any way to correct that problem?
Be very careful, that plastic breaks very easily. Loosen the plastic nut on the back and then hand tighten the ferruled **** on the front, then retighten the rear nut..easy does it!!
If it is not slipping-(not sure of your original post)-, try starting it and then maintaining the idle speed with your throttle lock while reducing the enricher-(choke).
Ds
Ds
+1 on being careful retightening the ferrule. I took mine off and tightened the nut to keep the choke from loosening. Put the choke back in its mounting bracket and started tightening the nut, then crack. The plastic snapped. I was pissed. I have been able to rig it to stay but very frustrating.
