Removing Rear Wheel
Removing Rear Wheel
So while i have been working on my motor i noticed that the tread on the rear tire was down to almost nothin. Since its up on the lift thought now would be a good time to remove the tire and go get a new one mounted.
Reading the manual it seems just too easy, take the bolt out and drop the tire out of the bike. hmm...so i look at the bike and i am getting this feeling there is more too it than that. So what I would like to know is any tricks, tips, or advice on doing this.
Is it truely this easy, take the axel nut out and move the tire ahead get the belt off and it just drops out? Do you have to mess with the rear brake caliper and brackets.
I think i will mark where the current location of the axle bolt is so i dont mess up my alignment. Anyway, any advice would be appreciated and a good read.
I have a 1995 Electraglide Classic. Sure does sound simple. Almost too simple, thats why I asked. haha. THanks
Removing the wheel is the easy part. Getting a clear shot at the axle, finding out that the wheel can't be moved far enough forward to allow the belt to slip over the sprocket without removing the belt guard (and the belt guard can't be removed with the wheel in place), those are the things that make it tricky. Lining up the wheel, spacers and brake caliper to reinstall the wheel is another matter, too.
I'm installing my rear wheel for the first time and the rotor and caliper is killing me. Does the caliper need to be removed? I can't seem to get the rotor in the caliper between the pads.
The caliper puck with the pads still installed then remove caliper then remove pads. A set of vise grips or channel locks may help using one disc brake pad to press on.
When I put a deuce wheel on my 93 softail I had to install the wheel an brake caliber, then slide the the rotor in, shove the axle in an put the rotor bolts on.
