So I changed out my primary oil and replaced with HD Syn 3 - 1qrt and adjusted primary chain to spec. I went for a ride with the wife yesterday with no problems. Then today I could here some noise from the primary?? Would this be due to the chain being to tight or to loose or to much oil?? Thanks in advance!!
So EVOFloyd are you saying that using Syn has caused that noise? When you say to use the same oil it came with are you saying the Tranny oil that it came with off the line from Milwaukee?? Please elaborate a little more!
Thanks Lang that's what I'll be doing for sure. I definitely set it a little over 5/8 so to be more on the loose side than tight. As for oil I read a lot of good on HD Syn 3 for the primary and didn't realize that Syn would cause some chatter! Lang what do you use? As for pulling she's strong as ever with no jerkiness or lagging!
Reason: Forgot to add some info.
