Cam Shim Question
Old 07-28-2012 | 06:47 AM
Doug S's Avatar
Doug S
Sorry to hijack but I want to be clear since I'll be in the cam chest this winter.
The tabbed thrust washer goes up against the bearing, if a shim is needed does it go inbetween the thrust washer and the cam or on the end with the gear and bushing??
Thanks
Ds
Old 07-28-2012 | 08:00 AM
miacycles's Avatar
miacycles
You need the washer with the ears against the bearing. The ears keep it from spinning and wearing the cases down. any additional shims go between the tabbed washer and the cam.
John
Old 07-28-2012 | 08:29 AM
Uncle G.'s Avatar
Uncle G.
Mine didn't have a tabbed washer, either, just a large plain washer. I'm still confused. It's been that way for 80,000 miles to the best of my knowledge.
Old 07-28-2012 | 08:34 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by lieutenant G
There was nothing that looked like that in the cam chest. but, there was a large washer that went between the cam bearing and where I would put a shim. I bet that washer was supposed to go back in there.
I don't have the "tab" washer in mine, either, just a large plain washer. From what I'm gathering by this discussion, '88 and up OEM cams are longer and may not need an additional shim. Aftermarket cams are made to fit all years of Evos,and thus, are shorter and may require shimming in later Evo cases. Is that correct?
Old 07-28-2012 | 04:17 PM
Spanners39's Avatar
Spanners39
Yes....and I have never seen a tabbed cam shim in an Evo but then I haven't pulled a pre-88 Evo Big Twin apart recently.
Old 07-28-2012 | 04:39 PM
Spanners39's Avatar
Spanners39
Sometime around 1992-93 the tabbed shim was dropped according to the parts books.
Old 07-28-2012 | 05:47 PM
Doug S's Avatar
Doug S
My 94 had the tabbed washer but the putz who last worked in the cam chest ground off the tabs saying they made noise...I've only once let someone other than me work on my bikes and I'm regretting it two years later....My dealer said the tabbed ones were no longer available and to just use the round one...but that's a dealer
I have a new tabbed washer and am figuring out my cam options with an eye towards doing the job late this season, depends on some knee surgery..
Ds
Jkeldoc (03-18-2022)
Old 07-28-2012 | 07:17 PM
Spanners39's Avatar
Spanners39
That odd because the 94 exploded diagrams show the round washer...I don't think it makes any difference, most shims are free to rotate,
Old 07-28-2012 | 08:18 PM
lieutenant G's Avatar
lieutenant G
Mine was round and to answer Dougs question, I put it back where it came from -against the bearing- and put the shim between the washer and cam. When your in there it makes much more sense to do it this way.
jmd897
Engine Mechanical Topics
14
06-14-2019 11:27 AM
94 ultra
2014-2023 Touring Models
10-23-2016 08:44 PM
Dyna7
01-06-2014 12:10 PM
swensos
EVO
02-03-2011 08:40 PM
Ric27
Exhaust System Topics
03-28-2008 09:55 PM
Quick Reply: Cam Shim Question
