Arlen Ness Throttle Roller?
Feeling some slop in the throttle assembly. Not sure if the plastic sleeve is worn or what. Also, it has in & out play of about 1/8". At the end of the grip is moves front to back about 1/8"-3/16". Wondering if that AN bearing thingy in the J&P catalog would eliminate this and let the throttle roll on nice and smooth. You're suppose to cut 1/2" of the right side of the bar to make it work.
RE: Arlen Ness Throttle Roller?
ORIGINAL: Tucker99
Yup, previous owner put on stainless braided cables and they suck. Howdja know? Is this causing my problem?
ORIGINAL: Tucker99
Thanks Low Rider,
Not sure what adjustment you're refering to. The only adjustment I know is the push/pull cable freeplay adjusments at the elbow. Didn't know there was an adjustment for the grip.
Thanks Low Rider,
A thread from the dead but see in-depth whinge, here. https://www.hdforums.com/forum/gener...l#post14422753
Received 4,361 Likes
While I agree with you (I tried one too) that it is a pos piece there was no reason to resurrect two threads to make your point.
