.030 over bore questions
Hey guys,
Got a 99 fatboy and found some .030 screamin eagle pistons, is this an unsafe overbore? I was told that this may be too much, but wanted some peoples opinions that have bored this far, or have any knowledge on this. Want to make sure it is still reliable.
Thanks for your time.
Matt Wenning
twostout4u@hotmail.com
Matt Wenning
RE: .030 over bore questions
I would bore the cylinder to whatever size it needs to be correct, then get the right pistons for that bore. Example, if you only need to bore it .005" to correct any problems then get pistons that are +.005". If you go right to +.030" you can not bore that cylinder again and it will need to be replaced if you have a problem.
The only +.030" SE pistons I see listed are 22768-98, are these the pistons you are asking about? If so, those pistons are designed for use ONLY with SE EVO Performance heads.
Roadflyer
Engine Mechanical Topics
03-12-2016 12:41 PM
128auto
06-22-2013 01:50 PM
