Front wheel play
Front wheel play
I've been noticing that when I go around a corner on Bertha, I hear brake noise, then, when I straighten out, it goes away.
I put her up on the lift and found I can grab the wheel top and bottom, and "wiggle" it a very small amount.
Is this normal or do I have a bearing problem starting?
Bertha has super duper tapered roller bearings. In the service manual it calls for a small degree of slack, however without digging out mine I don't recall what it is. If you can feel it that may not be good. If you spin the wheel do the bearings make any noise? If so, time to replace'em. They are not expensive.
When I shopped for front wheel bearings some years ago at a local auto parts store, the chap behind the counter took one look and told they were off a small Ford car. He was wrong, but the bearings were the same and cheap!
Thank you sir! I have the bearings already, but I need to find out if they fit the after market wheels NGH put on her.
Is this something I can do myself(changing the bearings), or does it require special tools?
On edit, no noise (except the brakes lightly rubbing) when I spin the wheel.
