New stereo for my 86 Electra Glide Classic
Have the same setup and totally agree with Rivercityslim. But I'm still struggling with those puny 4". Went through three different models already - they all suck, i.e. you cannot crank them loud enough while riding w/o severely distorting the sound ![Frown](https://www.hdforums.com/forum/images/smilies/frown.gif)
So Jclind1966, you are saying DB401 s are really good indeed?
![](http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/ImageHandler/fixedscale/400/300/products/2012/8/113/x113KFC1093-o_front.jpeg)
I put in a set of Kenwood KFC-1093pf 4" - 3 ways and I'm surprised how much power they take and how much full range sound. I often have to adjust the highs down. Keep in mind they are only 4", too many expect concert level sound out of them.
One thing you need to do once the stereo is installed is to set it up. Park someplace where you won't disturb anyone and turn the volume up as loud as it sounds clear. Then start adjusting your tone controls.
When I hit real loud I have the tone settings to allow the speakers to play without distortion. Often this means some bass sacrifice, and in my case I felt the highs got too crisp. But now when I crank it up, it sounds clear and precise at the loud volume I set it up at.
My in dash unit is a kenwood also and has the ability to power rear speakers and a subwoofer. As I scroll through all the tonal settings it's very complex with even the crossover frequencys adjustable, and mid range controls. No more bass on one side of a single dial and highs on the other side like an old car radio.
So tuning the tone can really improve what you hear at loud volumes. Give it a try.
did the Kenwood KFC-1093pf fit in the fairing ok? and did you use the covers that came with the speakers?
I have a Sony (I forget the model number) that has two digital inputs. There is an aux input that accepts a mini plug from an ipod and a USB input that I plug a flash drive into. With the flash drive in the USB, I can still control tracks etc. using the handlebar controls. After having these options, I can't imagine buying another unit that doesn't.
I bought a kit from Biketronics that allowed plug and play with the stock wiring harness, so the handlebar controls still work, and the radio itself fit nicely in the stock opening. I also replaced the speakers at the same time, but forget which kind they were. There are several different kinds of 4" coaxial speakers out there that would be an improvement over the stock speakers.
My stock head unit was the shaft style I had to cut it to fit the new din radios
I just went ahead and ordered this radio for my Tour Glide. I already gave up on the handlebar controls and the front USB jack will come in handy with flash drive music. Just have to upgrade the speakers next; the Scoshe ones from Walmart suck! LOL!
http://www.heavydutyradios.com/jhd_3620.html
The Jensen HD radios are awesome but they have a large amp that draws a lot of current which is great for sound quality but to deal with the current draw I ran a cable from the battery to behind the dash into a relay and connected the relay to the factory ignition line for the factory radio so it still works with the ignition switch
