click jerk
Old 07-02-2012 | 08:37 PM
Spanners39's Avatar
Spanners39
Welding the casings like that is a mission because you gotta get the welded area true and flat with the rest of the case without taking too much off the case or the clearances will be wrong. It isn't that it can't be done but is a PITA.....swap meet time!
  #72
Old 07-02-2012 | 09:06 PM
RidemyEVO's Avatar
RidemyEVO
Ya I thought the same as I walked into work tonite, but I'll know better for sure in the next couple weeks if it holds the fluid. Any idea upto what year case would do the job?
  #73
Old 07-02-2012 | 09:52 PM
Spanners39's Avatar
Spanners39
No idea on the cases but I don't think they changed until 2006 when the 6 - speed came out.
  #74
Old 07-02-2012 | 09:56 PM
RidemyEVO's Avatar
RidemyEVO
I beleive your correct, I'll have to do a bit more research on that.
  #75
Old 07-03-2012 | 05:52 PM
Spanners39's Avatar
Spanners39
Part number will tell you heaps.
  #76
Old 07-03-2012 | 09:43 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Spanners looks like I'm swapping out the tranny, drain Plug threads are shot and the 1/4" rod fix I did is leaking. But on the bright side the tranny was sooooooo smooth. I started a new thread as I'm sure you can share some of your tricks there.
Craigny
06-27-2019 06:39 PM
SportsterSnow
06-14-2013 09:14 PM
jfsgb
Shovelhead
17
06-20-2012 02:31 PM
polish hammer
EVO
01-17-2012 04:26 PM
OneBlackFly
09-13-2007 12:48 AM
Quick Reply: click jerk
