What the he** happened?.
I went for a well deserved ride yesterday after power washing the house, and after a 40 mile ride I noticed oil leaking from the 2 bolts that hold the back of the air cleaner on [ its the stock one]. Front and back one. Oil is running towards the front of the front head and getting blown around,and on the rear of the head and dripping on the exhaust and trans cover. I didn't change anything like the oil, so how does a simultaneous leak happen?.,,
If you never had a problem with oil leaking from the crank case breathers, something could have gotten plugged up and your motor might be sumping. You don't say what bike you have; older motors had a check valve that if the spring broke could allow oil back into the engine. Your breather valves could be plugged up or worn out. Also if there's too much oil in the oil tank, this will force oil out the breathers. Most bikes will leak a bit of oil which is more mist than anything (that's the purpose of the breathers in the first place). If you all the sudden started dumping oil out where you never had a problem before than something changed and is plugged up or broke.
Received 4,209 Likes
It is possible that they are simply loose and need to be tightened. Use a torque wrench...10-12 ft. lbs.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
