Speedo stopped working help.....
Old 05-07-2012 | 06:44 PM
Deebz's Avatar
Deebz
Originally Posted by grbrown
Are you sure there is something in there? That end of the cable inner is simply squared off, so is no larger than the round part. You should be able to see a square socket in there, around 1/8" or so across.
I can definitely see whats left of the broken end of the cable stuck in there, it still spins when I turn the tab thing goes into the brake disc.
Old 05-07-2012 | 06:48 PM
Deebz's Avatar
Deebz
I just got it out.....it broke off and was stuck in there....I used the little scissors on my leatherman to pull it out!!!!!!! YAY.....just need a new speedo cable now......thanks for your help youz guys.
Old 05-07-2012 | 07:08 PM
Dr.Hess's Avatar
Dr.Hess
I suggest a Genuine HD replacement speedo cable. I've tried the aftermarket ones, and the HD one lasts longer. Also make sure you route it with no sharp bends in it.
Old 05-07-2012 | 07:10 PM
Deebz's Avatar
Deebz
Yeah gonna hit the Harley shop tomorrow...I'll specify that, thanks.
Falcon195
06-09-2018 09:18 PM
leadmike
02-18-2017 02:15 AM
tv200
11-02-2015 03:30 PM
Tee&Vee
EVO
04-29-2012 07:45 PM
trozenhorse
03-08-2009 09:14 PM
Quick Reply: Speedo stopped working help.....
