What could have broken (towed home) technical question!
Ok, went for a ride yesterday and coming to a stop my cluch decided to not function anymore. I came to a stop and it stalled out, I looked down to expect my clutch cable to have possibly broken but it was fine. My clutch arm however was able to be swung back and forth with my finger. My first question is how the clutch system in this transmission works and second, what could have failed? I was engauging the clutch when somthing broke so it had strain on it. It will be going to Harley monday for repair but I am just wondering what I should expect!
Thanks for reading
Jesse
Thanks for reading
Jesse
Sounds like the cable, although they look as if they came from a suspension bridge, so it always amazes me when someone says one has broken! If you have an external clutch lever you can remove the cable very easily at both ends and check it for yourself. If it is broken, it as easy to fit a new one!
I recently replaced my original stock cable (I've owned my 1990 bike from new) with a Diamondback. It is quite expensive, but far smoother and lighter in operation than the stock variety. A treat worth considering!
i would say it's the "release finger" part #37084-79. it's inside the 6 sided cover on the trans. they're about $10 and it's not a hard fix. bike on the kick stand, drain the gear lube, take the cover off. nothing will fall apart when you take the cover off. the fingers are attached to the clutch lever. take the broken part off, put the new part on. it's less than a 1/2 hour job.
