dual plug heads firing order?
I just had my heads off to be worked on and now that I have it all back together it doesn't seem to run right. is it possible I got the plug wires on wrong? What is the correct firing order for dual plug heads with two coils? I have an fxef 93 cubic inch '81 shovelhead.
It depends on your ignition system, if its still on points they will both fire together so there is no order as such....if you got a single fire electronic system you will need to look up the fitting indtructions online....all the manufacturers have that info on their websites. Hope this helps.
You could just swap the leads round and try starting the beast....
Woods Glen
10-23-2010 06:52 PM
shovel201
02-25-2008 04:32 PM
