Anyone install a Time Sert
on the bike w/o pulling motor and splitting cases?
Any tricks of the trade?
Unfortunately the heli-coil which was in it is not holding. So gonna do the right thing and install the time sert.
When I installed the heli-coil I had taped up the bottom of the hole and made a small vacuum hose and used a ton of grease to capture any metal chips.
Any tips?
When you say right rear head stud are you talking about the exhaust stud? With the time serts as long as there's enough material to accept there outer threads your ok but you must keep it 90 degrees to the surface, with the tools that come in the kit making room for the drill is usually the most difficult part.
Helicoils were originally invented for use in aircraft engines and other high performance applications, so if yours was installed correctly it should be fine. Every aeroplane in the sky is a close formation of hundreds if not thousands of helicoils! I have used them in the past as repairs with complete success, so don't change for the sake of change.
Had another thought, when you goto use the drill put lots of thick grease on the bit and clean the bit often each time you go into the hole and thats the same with tapping the hole, it doesn't take a high rpm on the drill. What I did for the other holes because the crank is right there is I put an old picture layers with grease and slipped it under the case lip where I had to drill to catch anything and before I pulled the picture out I cleaned the hole of the grease which held the metal that didn't get stuck on the bit grooves, which reminds me pack the hole full of grease before drilling, the more grease involves the more control you'll have.
I'm actually quite familiar to Time Serts. I have a kit already which I have used on my F150 for the ever so popular plug blow out. I also used tons of grease and made up a small vacuum tube when doing so.
When I installed the heli-coil last year I also mudded it up well with grease too.
I also know how to install a heli coil correctly and it was installed perfectly but those heli coils do NOT always hold up.
I've wrenched and machined for over 25 years and have seen them pull out on BB Chevy's, Ford, etc...and although they usually work fine they sometimes fail.
I was just looking for some other advice for doing this job on the bike, and I do appreciate all the feedback and will no doubt "get r dun"
