cam bushing in nose cone
I tore my motor down this past year to regasket it and change cams, I've noticed it has a little wear on the cam bushing, so I purchased a new one from the stealership and it doesn't have the oil passage drilled nor instructions on how to, with that said, any pointers and what size bit should I use, thanks chad
The manual says " Drill lubrication oil hole through wall of bushing with 0.156 in. drill using oil hole in bushing boss as a drill guide"
It also says the bushing needs to be line reamed, to remove burs, and to ensure perfect alignment, for that the case need to be split.
That's all I got, I left mine in, so I no experience with putting one in.
The case doe not need to be split, you just need a right side case to use as a guide for the reamer. Many shops will have saved an old case just for this purpose.
Be real sure that you need a bushing replacement, I changed my cam cover to chrome and the guy I bought it from installed new bushings and reamed them with the case half he has and I got a very unpleasant whine when I installed it. I ended up buying a brand new oem chrome cover to remedy the problem.
Pinion bushing wear will lower your oil pressure, I'm not quite sure what cam bushing wear will effect.
