I'm baffled with BAFFLES!!!!
So I purchased and installed a set of Cycle Shack slash-up slip-ons on my EG. I love the way they look and I got a smokin' deal on them. Only problem is I hate the sound. Way too quiet. I'm a hot rodder. I like 'em loud.
I take the bolts out that "hold" the baffles in and I'll be snookered if the stupid things will even move. Anyone know of a way to get them out without taking the mufflers off the bike?
I hook the nut that the screw was screwed into inside the baffle with a long allen wrench that is locked into the jaws of a pair of vise grips. I then pull the baffle and work it out far enough to where I can grab the baffle with the vise grips. It can take a while to work it out because the baffle media tends to hold it tight inside the pipe.
Well, I tried everything and the only thing that worked was taking them off and pushing them out with a hammer handle from the front end. I was able to get one to move a hair with the allen wrench trick, but that's it. Sounds great though. Not as loud as my Sampson's, but lower and more growly.
Slide hammer is the way to go. You can make one out of some threaded rod with some large washers and a nut on the end, piece of heavy pipe for the slide. I use a 2 foot piece of rod with a hook bent on one end and the other bent like a U. Take your airchisel without a chisel in it, put the short end of the U in it and hook the other end of the rod in the baffle...yanks them right out with no fuss, everytime..
Doug
Doug
Doug
Doug
