building a 80's softail have a chance to snag a 92-99 evo?
Old 03-28-2012 | 06:25 PM
polish hammer's Avatar
polish hammer
Default building a 80's softail have a chance to snag a 92-99 evo?
what are the differance between 80's evo's and 90's
would i havta change primary?
Old 03-28-2012 | 06:37 PM
jsbridgew's Avatar
jsbridgew
early evos are 'bottom' breathers... later evos are 'head' breathers
also, it's my understanding that the early evos have the superior torrington b138 inner cam bearing, while the later evos have the inferior INA bearing
i think both have inferior harley 'A' lifters which should ideally be swapped for 'B' lifters ....although, i just rebuilt a 96 evo for a buddy of mine that had over 65k on it and both the INA bearing and 'A' lifters were solid
could be more differences, as some others might chime in ... there were some differences in case design, as well, i think....not sure if the problems were with the earlier case designs or the later (weak spot)....anyone?
Old 03-28-2012 | 07:06 PM
FXD_One's Avatar
FXD_One
My 98 Dyna Super glide had stock "B" lifters and the torrington bearing.
Hope this helps.
Old 03-28-2012 | 07:34 PM
polish hammer
i shoulda been more specific i mean will an 92 evo from a softail fit in a 87 evo softail?
polish hammer
but thanx for the knowledge!
Old 03-28-2012 | 08:22 PM
polish hammer
anyone know will newer evo fit in the earlier evo frame?
Old 03-29-2012 | 05:56 AM
jsbridgew's Avatar
jsbridgew
Hope this helps.
...this is correct
i believe they went back to Torrington bearing and 'B' lifters in 98 because of the problems
Old 03-29-2012 | 10:30 AM
Silver Ghost's Avatar
Silver Ghost
My 90 has a 96 evo in it, so yes, it should fit. I believe 92 was the the year they started with the more robust cases, new oil pump and head breathers.
Old 03-29-2012 | 03:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
HD did not go back to the Torrington.
________________________________________
It will fit fine.
Old 03-29-2012 | 04:44 PM
jsbridgew's Avatar
jsbridgew
...you are correct, dan
pardon my ignorance...lol
Quick Reply: building a 80's softail have a chance to snag a 92-99 evo?
