Jiffy Stand and Forward Controls
So, I am finished getting parts for my build and I am fitting stuff to check for fitment before tearing it down and painting. Looking at my 1998 softail manual (my build is very loosely based on a 98 FLSTC and I have a aftermarket Kraft Tech frame for that year), the mounting points for stock Harley forwards is very different than my forward controls. My forwards use all three holes on the primary side of the bike. So, how do I mount the jiffy stand? I have a new one that is for my year and comes complete with everything. Or, am I missing something here?
I'll see if I can get a pic up explaining what I'm talkin about.
jim
1st
![](http://i1195.photobucket.com/albums/aa397/msgtarmor/IMG_0330.jpg)
2nd
![](http://i1195.photobucket.com/albums/aa397/msgtarmor/IMG_0329.jpg)
3rd
![](http://i1195.photobucket.com/albums/aa397/msgtarmor/IMG_0328.jpg)
Your's may not be the same as mine but I'm fairly sure the basic mount-up is very similar... Hope this helps!!
jim
I have aftermarket forward controls that use all three holes on the primary side of the bike. I will try to put the controls on tonight and take a picture and of the jiffy stand. It does not mount the same way as the stock controls shown.
If your shifter is like most it is mounted to a plate with several holes with the shifter shaft assembly going thru it at the top. The plate will mount to the 3 frame holes thus mounting the shifter. And if I remember right the side stand will also use one of the 3 frame holes and then 3 others on the shifter plate.
jim
jim
jim
jim
I believe I may have answered my own question. I relooked at my controls online and I believe they have extra holes I did not notice in the mounting part for the jiffy stand. I will check during lunch and let you know. Thanks for the posts. You may me think and re examine which is always good.
I know the billet ones are different but I figured it would help get him thinkin in the right direction!!
jim
If your forwards only have three holes, they are not designed to mount a kickstand in the stock position. Most people use one that bolts on behind the primary ...your frame may or may not have the holes to mount...here's a link only because they have the best pics.
http://www.ebay.com/itm/CHOPPER-CHRO...5601%26ps%3D54
