Welded nut under fender
1 of the 2 welded nuts under the seat snapped when i removed the passenger grab rail. It looks like that is where the driver back rest mounts? Is there an easy like clip in solution like is available for the rear seat attachment bolt? Or do i have to pull off the tire and tack a new bolt in and hope not to burn a hole or make a bigger rust spot haha?
Will this work?
http://www.jpcycles.com/product/8200012
Or this?
https://www.denniskirk.com/landmark/...prd/H27138.sku
Or this?
Get a nut and bolt larger than your seat bolt and drill and tap the bolt through the head. Put the bolt through the existing hole and tighten it. Then mount your seat through the hole you tapped. Use a stainless bolt with a low profile head and a lock nut with the nylon. This will also protect the paint on your fender.
Received 4,361 Likes
