Chrome Primary Cover leak
I bought my '85 FXRS last April and replaced the clutches soon after. When I put it all back together I put a brand new gasket on the primary cover. By the time I stored it for the winter it had started leaking on the bottom. I'm not sure if the chrome cover is stock or was put on later. Anyone know how to check if it's warped? If it's not warped, anyone have any tips to prevent it from leaking again once I put on a new gasket?
The best way to check the cover to see if it is warped, or bent, is to stop at the local hardware dealer, ask to look at the discarded glass section, and purchased an old piece to use. My local guy in town has lots of old windows that have been changed out. Usually can get a piece for about five bucks. Lay your cover down after you've cleaned out all gasket material and visually check for gaps. You can even spray paint the glass flat black, and leave a small circle unpainted to shine a flashlight through from below. Gaps show up very easily. You may then try to take out the warp... or use a local machine shop to plane it for you. Best of luck. I also use the best gaskets I can anymore, usually aftermarket, such as James or Cometic for all my work. I am NOT a fan of any gasket sealants, but it is only a personal preference.
Received 4,361 Likes
