Rear Wheel Alignment
Old 03-13-2012, 10:15 PM
traildog's Avatar
traildog
traildog is offline
Default Rear Wheel Alignment
I found that the sprocket on Bertha is rubbing the frame when I make a turn.
It looks like the wheel might not be quite straight.
How do I confirm and adjust that?
Old 03-14-2012, 12:56 AM
Jethro's Avatar
Jethro
Jethro is offline
I am going to assume when you mean "not straight" you do not mean offset to one side, but looks like it is turned in one direction. Which also means I assume that it has been adjusted for belt tightening and perhaps the adjusters are no longer equal in the placement of the axle in the adjuster plates? You can actually measure the spacing you have in several ways, probably the most accurate and easiest is to take a micrometer and measure the distance from a fixed point--you could even use the center of the axle--to the frame, and then tighten the adjusters for an equal setting.
I've had a few beers tonight, just got back from about seven hours of putting my bike top end back together, so I may be reading this wrong.
Old 03-14-2012, 03:12 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
There are two different alignments that may need checking here. One is called 'vehicle' alignment, the other is wheel alignment. The engine/trans/wheel assembly is rubber mounted and can be adjusted within the frame. The procedure is in the factory service manual and is best read while in a darkened room!
Wheel alignment, of the rear wheel, is also described and there are various ways of successfully doing that. Jethro has put his finger on it and a minor adjustment of the wheel in the swingarm may solve the problem, while also keeping the belt correctly tensioned.
I recommend doing both, to ensure your bike is just right.
Old 03-14-2012, 07:33 AM
traildog's Avatar
traildog
traildog is offline
Thanks guys! I must have missed it in the manual. I'm going to take a hard look at it today. Heck, I may even play hooky. 78 deg and sunny............
Old 03-14-2012, 10:51 AM
dwatkins's Avatar
dwatkins
dwatkins is offline
You mean when you turn the wheel while on a jack or while turning a corner when riding?
Old 03-14-2012, 11:02 AM
schwangster's Avatar
schwangster
schwangster is offline
Howaed @ Motorcycle Metal has a great tutorial on how to align front and back
http://www.motorcyclemetal.com/Download18.html
And you can have a look at the Ohlins while you're there....
Old 03-14-2012, 07:07 PM
traildog's Avatar
traildog
traildog is offline
Took it to the local shop and found it may have other problems like a
bearing.
Not only is the tire rubbing the fender, the rear sprocket is hitting the swingarm when I turn.
I'm not taking any chances and I'm gonna let the shop figure it out.
Old 03-15-2012, 04:50 AM
dwatkins's Avatar
dwatkins
dwatkins is offline
Yeah I was thinking a bearing or something loose. Shouldn't be that much movement back there for sure.
Old 03-15-2012, 08:04 AM
traildog's Avatar
traildog
traildog is offline
Never really looked too hard, but I don't think I have Ohlins.......
Old 03-15-2012, 08:06 AM
grbrown's Avatar
grbrown
grbrown is offline
You mean "not yet"?!
Quick Reply: Rear Wheel Alignment
