Ultima engine for touring bike?
#31
#33
Well if I end up that way I will look you up. May be in Anderson SC early may, but I have about 400 miles on it so far, starts right up, but has a cough from the Carb right off idle intermittently. Also started it up the other morning and it was idling great, then instantly off, no stutter or stumble just off. Not sure if related, but thought I would share.
#34
#35
Remember most aftermarket exhaust try to set up for the most common engine combinations out there. Usually this is an 80" engine and you are putting 50% more through it. Does this light a light bulb for you??? A good 2-2 exhaust set up for a 96"+ engine should make a difference in torque which is overall more important than HP.
#37
#39
quick update
Ok head physically looks fine, yet I lost compression in the rear cylinder and it was making some horrible noises that sounded like rear head. So far everything in the head looks fine. Later I will be pulling the cylinders and lifters, and if still nothing obvious the cam. Otherwise i'm out of ideas.
Also John Sachs didn't seem like he wanted to do the head work when I emailed him.
