Bad Miss at Low RPM
Bad Miss at Low RPM
Hi All
I just got a 1993 90th anniversary Wide Glide with 9,100 original miles. The bike looks great and has only a few minor issues. The first being a very minor weep from the base gasket on the rear cylinder. The second issue is that the bike seems to have a pretty good miss in the low RPM range. Once you cruise at about 60 in 5th gear it seams to run fine and when you are really getting on it, it does not miss a beat. But when you are lopeing along at about 30-35 it coughs and misses a bit. I know that the bike sat for awhile and the carb probably need gone through. My plan is to just send in and get a killer carb. But is there something else it can be? I have heard that it could be an exhaust valve but I am not sure and I am just looking for your thoughts.
Thanks in Advance,
Phil
Thanks in Advance,
Phil
Does it spit back when it misses? In which case it could be running lean low down, it could also be running rich due to probs with the accellerator pump but in every case of misfiring with an Evo you should start by changing the plugs....Evos' are really fussy about plugs and they may look fine but can throw up a range of symptoms.
Hi All
Thanks in Advance,
Phil
Thanks in Advance,
Phil
Do you get a backfire/pop letting off the throttle? Such as when shifting gears or coming from a 55mph run to a stoplight? That would show an intake leak. Also it can leak thru the rod your butterfly is on. This happened with my Super B. If the rod wobbles any when you pull on it, it's shot. (Rebuild kits are available for this problem).
