Bad Miss at Low RPM
Old 03-12-2012 | 11:02 PM
the blob's Avatar
the blob
To me the plugs look a tad lean. I say up pilot jet to
45 then 2 turns out on mix screw.
Old 03-13-2012 | 12:16 AM
V2Evo96's Avatar
V2Evo96
If it's fuel starved due to crap in the system or an extra filter and it's running rough at low speeds I would think it would be worse at higher speeds when more fuel was required.
Also an intake leak can show up on the plug that's in the head that has the leak. Eg you would see one plug reading differently to the other.
I can't see your plug pics as work has me blocked from pics, but grey/greyish white is the "old tan" we used to see. Newer fuels don't color plugs like they used to.
I have also seen cam/exhaust combinations that just will not run steady at lowish/mid speeds but run fine at idle, high speed and WFO.
If it were me I'd clean the tank and wire mesh OEM screen, get a carb rebuild kit and then as others suggested adjust your air/idle screw and then finally change the pilot jet to the next greater size if it still runs poorly.
Are you sure the bike is stock? (at least you have some things to think about/check into).
ADDED: Congrats on your low mileage find!
Old 03-13-2012 | 04:32 PM
dragonx's Avatar
dragonx
Thanks guys you are awsome. I will try all these things and let you know what happens.
Phil
Old 03-14-2012 | 09:08 AM
badcooky's Avatar
badcooky
I set my fuel screw to where I want it by ear and then let her idle for a while and then pull the throttle on and if it hicks i screw the fuel scew out a quarter at a time till the hick goes away.
My Evo's throttle snap is instant all me mates can't believe how sharp she is on the throttle.
This works for me.
HTH.
jokenroll
EVO
28
09-25-2012 11:50 AM
berndog
Shovelhead
07-24-2011 03:37 PM
kiowadriver
Shovelhead
10-13-2010 07:19 PM
Doc2nd2
Carburetor Related
02-04-2010 02:10 AM
fmbeach
07-27-2006 03:38 PM
