Baffle question
Old 02-25-2012, 08:00 AM
traildog's Avatar
traildog
traildog is offline
Default Baffle question
Took my pipes off and found this hole in the header ( I think that's what you call it).
Can a baffle be installed here?
Old 02-25-2012, 09:16 AM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,795 Likes on 893 Posts
Looks like someone was doing the lollypop washer trick being mentioned on here or had a Big City Thunder baffle in it. it is a sleeve that already has a restriction device (lollypop) built into it, that hole is in the area where the Big City baffle would be installed.
Old 02-25-2012, 09:18 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
All the baffels that I know of are placed at the end of the tailpipe. I don't know why you would put a hole in the header like that. You might ask NGH why it is there.
Old 02-27-2012, 07:54 PM
hatchetman's Avatar
hatchetman
hatchetman is offline
That pic shows a heat shield, not a pipe. Is there a hole in the pipe???
Old 02-27-2012, 08:01 PM
1997bagger's Avatar
1997bagger
Could be the hole where Bertha has her period, I don't think NGH has told you everything!
Old 02-27-2012, 08:05 PM
texashillcountry
Dirt don't hurt
Damn man I just shot beer out my nose. LOL
Old 02-27-2012, 09:13 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
From the pic,.... that bolts to the head? Dumbest thing I've seen. Why would someone put a hole there? Must've sounded like crap!! I've not seen or saw it all, but seems strange.
Old 02-27-2012, 09:24 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
The Big City Thunder baffles go there if you are running mufflers. That is what they say on there web site. The reason being that the baffles will not fit the mufflers, and I think it is for those that have punched out the muffler baffles.
Old 02-28-2012, 03:55 AM
traildog's Avatar
traildog
traildog is offline
No. That's the end that the muffler slips on to. I have not checked the other pipe, but I'm guessing it's the same.
I ordered a couple of cheap baffles to be mounted in these holes and will report back after I try them.
And, she sounded great when running. I'm just trying to tone her down a bit.
Old 02-28-2012, 04:55 AM
badcooky's Avatar
badcooky
badcooky is offline
Same.
No you shouldn't put a baffle in a heat shield.
Quick Reply: Baffle question
